ORIGINAL: gordesky1
why do i always have to heat the engine up with a hair dyer for it to kick over?
even when its warm like it is now 55c i still needed to do it...
my t-maxx .15 never needs the hair dyer even when its 20s outside.
at first i thought it was just a bad plug but i have a new one in it.
when i take it with me to work which i drive it in a big parking lot it sucks when i have to take it back in the truck and turn on the heat and wait for it to heat up...
The reason you need to heat the engine up is because the pinch on the engine is so tight. This is a good thing and you should be happy about it, means you engine still has gobs of compression. It will slowly loosen up though.
