RE: Anyone running Blade 400 with Align 430x motor
Yes I'm running the stock ESC with the 430XL. The stock Eflite motor and the 430XL are close enough that there is no problem. I did have to ream out the motor mount hole slightly to use the Align motor but that took only a few minutes.
One advantage to the Align 430XL is that you won't rub the battery. This motor has a can cover.
