ORIGINAL: rcpollo
Just started building my Venus II. Reading a lot of the reviews, I can't wait to get it up in the air. Will be using a reconditioned YS 120 that came out of a Fresh Aire I had just reconditioned. Five flights into it, a wing sheared in half and that was the end of that. Since the engine was running sweet, I needed a replacement ASAP. Venus should fit the bill. Anyhoooo, one of the first step in assembly is to epoxy the wing joiner to a piece of plywood. Mine came already glued. Is that the same for y'all?
I had to glue mine together. Check it out good. It could just be stuck together.
