RE: Mark Engines (Hungarian Moki) Announces New 1.40's
If you look at HObbypeople's website and check out the replacement parts for the engine, you will see what they have changed...
I know the 1.80 Connecting Rod , Wrist Pin, Wrist Pin Ball, Front Bearing,Cylinder Head, Piston & Sleeve
are all gas engine specific..... Which is more than saito can say about there gas engines!!!
I don't know about the 1.40 because it is new, and they have not listed the 1.40 glow parts yet...only gas...
I can assume that they have done this one the same way, as it is the new engine that they came out with!
I am going to get one...
either the 1.40 or the 1.80 gas... I have had it with glow, and all the problems associated with it..
Unless.... it is a special multi-cyl. glow engine...
