RCU Forums - View Single Post - CRRC 40cc kit
Old 03-20-2009 | 08:15 PM
  #92
ROCKY1405
Default RE: CRRC 40cc kit
Hi Guys: I just completed assembling my GF40I kit and am busy making a test stand for it. I notice the carb on mine has a choke set up that once set, releases if you give it any throttle. So, unless the throttle is completely closed, the choke will not stay on. I've never seen one of those before and am wondering if all the GF40i's come with that same carb set up. Also, on mine, the throttle arm is very short and also has very little clearance between it and the intake manifold. A clevis is the only way I'm going to be able to hook up the throttle linkage to mine the way it is. A more secure, bolt-on connection would hit the manifold and jam. The question is: Is yours the same way or did I just get and odd one?
Thanks! [8D]
