RE: DL-50 engine
Most of the time you don't need any modification on the diaphragm on the carb. Unless you don't like following the 3 to 1 rule. 1 in, 3 out, on the cowl cut. Form over function. If it ain't running because of the diaphragm your exit hole probably isn't big enough.
