Flaperon Endpoints........HELP?!!?!?
It gets bizzare..the endpoints on the aileron will affect the flaps, the flap rate changes one aileron..The DR settings of the Elevator will affect the flaperons. Everything affects everything else. The % mixing E>F will affect the throws if the Ail or Ele or mix ratio is out of wack.
You can get it perfect..it took me a couple of tries (Futaba 8UHS) and I have the extra book!! I just kept at it and kept at it..Finally found the things that were jackin' me up..
And then I did exactly like Billy..copied every plane off that one template.
