ORIGINAL: victorzamora
I also crashed a Sig Wonder at full throttle (it had an evo 36 on it, so it was going FAST) hard enough to crack both my switch AND my Rx.
Please tell me that you sent the receiver in for service!! You hit hard enough that it tore the antenna off and cracked the case, but all you did was contact Futaba/Hobbico about getting a new antenna sent to you?
And as far as the reprimand for asking him to shut the CAPS off, he posted a fair number of posts in normal type. And again, while he may need larger type to read using caps is like screaming when you talk because you are hearing impaired. He can set the fonts on his computer so he sees only three letters at a time, but there is not reason that he has to type all caps. And all of this has been gone over several times.
