ORIGINAL: bonebreak
ORIGINAL: knarleysurfer54
Sweet thanks! Just another question.. My exhaust will hit my plane so I can't bolt it onto the motor.. Is there some kind of spacer I can buy?
Yes, there are spacers you can buy. As for the prop, do NOT use a drill bit (unless you have a drill press, and it's still not recommended). You will never get the hole straight, and will not balance or spin true. Buy a prop reamer.
Haha ok I will get a prop reamer! Where can I get a spacer? Tower Hobbies?
