 Prop Question >
Prop Question
Prop Question
Old 03-22-2009 | 08:08 AM
bonebreak's Avatar
Default RE: Prop Question
ORIGINAL: GRandolph
yeh, just use a hand drill. A drill press is not needed unless you are working for NASA.
Please don't use a drill. I promise the hole will not line up right. I ruined 3-4 props thinking I was a champion and didn't need no stinkin reamer. The hole was never the right size (too big no matter what bit I used since it is straight), and always drilled just crooked enough to where the prop didn't spin true. The reamer is tapered and makes the hole perfect EVERY time. Trust me on this, it's worth the $8.00
Old 03-22-2009 | 09:43 AM
the main thing to remember is the shaft size, you really shouldn't use an american thread size to ream/drill out your props when you have a metric size shaft and vice/versa, I have both SAE and metric reamers
Old 03-22-2009 | 12:22 PM
Does it have to be a reamer from great planes? Or will just any reamer work?
Old 03-22-2009 | 01:01 PM
andrewtexas123's Avatar
DONT use a drill if its not a dead straight hole your going to start your engine and there's going to be a lot of vibration. This vibration is going to loosen your prop nut and the prop and spinner are going to be come projectile.
Andrew
Old 03-22-2009 | 01:22 PM
ORIGINAL: knarleysurfer54
any brand will work, just make sure it's tapperred, otherwise you might run into problems getting it reamed out striaght
Old 03-22-2009 | 01:24 PM
  #31
Great [8D]
