RCU Forums - View Single Post - Winglets on Sig Cap 231 EX?
Old 03-23-2009 | 10:26 PM
MTK
Default RE: Winglets on Sig Cap 231 EX?
ORIGINAL: dick Hanson
SFG is -I believe - George Hicks idea.
George is an aeronautical engineer by training and vocation.
also a active modeller who does not "go along with the flow " when it comes to design work.
His little biplane foamie design "Tensor"sold by Horizon a few years back was an exercize in SFG uses.
If you tilted inthe roll axis- the model did NOT turn -it just drove merrily along with one panel down the other up. It was sometimes very disconcerting to fly as a turn, required rudder - always . I would say, as a model designer, he is as good as it gets if you are looking to figure out or fix an aerobatic setup.
EDITED
Geez, I know of George. I should have known that I suppose.
The original appendages on a model was pioneered by Nat Penton about 25 years ago give or take. George has discussed shop with Nat many times over the years. Nat is a good friend and we bounce concepts off one another occasionally.
MattK
