RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 03-23-2009 | 10:42 PM
  #4146
jedijody's Avatar
jedijody
Default RE: DL-50 engine
ORIGINAL: Bpar4
Finally got to the field around 4. After a couple of short runs on the stand to make sure all is well, got the Bling into the air. Ground data is: idle - 2400 and 7400 peak (at the end of my 2 flights). This thing is easy to start and pulls very hard. Starts on the first flip even when barely warm. This is great!!!! Will post pics soon.
Still having trouble getting the idle below 2400. The low needle is out over 3 turns. And it will go lower to 1800 but is rough and rich. I wonder if moving the timing a bit would help? Maybe a bit more run time will help. I don't think so because this is a fine running beast above an idle.
Glad to hear your new DL50 engine is running strong but the idle issue could have some unsafe side effects. If you can't figure it out you should contact your dealer to see about getting it looked at. The low speed mixture needle is not supposed to be used to drown the engine down to an acceptable idle speed, how are you shutting off the engine?
