You can check you clutch for broken or try loosening the glow plug a little when starting or try a different glow plug with a different heat range with a idle bar.
Make sure the glow plug is bright yellow. The engine should start in 3-4 puls. If not try adjusting the idle screw a little untill it fires.[8D]
