RE: Vertigo II Build Thread
Landing gear mounting:
Photo 1: Landing gear mounts: Outline and hole centers laid out. (holes drilled)
Photo 2: Parts cut to size. Material is 1/8 ply. Small holes are for 1/8" dowel to anchor into foam. Larger holes are for 4-40 blind nuts.
Photo 3: Check fit of the Spring -Air mains.
Photo 4: Lay-out of the LG mount recess. Wing plan drawn in AutoCad, plotted 1/1 scale for template.
Photo 5: Skins cut and removed.
Photo 7: Cutting LG mount recess using handy cutting tool. (Coat hanger wire in soldering gun).
To be continued.
