RCU Forums - View Single Post - Opensource CDI ignition
Old 03-25-2009 | 05:05 AM
  #272
Futterama
Default RE: Opensource CDI ignition
Try opening the .c files in MikroC, and try opening the spreadsheet. You will se that you need to copy-paste data from the spreadsheet to MikroC. You then use MikroC to compile/produce the .hex file that you will load into the PIC using a PIC programmer.
