Hi, here is my set up and my problem...
I have a Tamiya Lunch Box (Re-re), it came with an
TEU-101BK Electronic speed controller (ESC)
I am using a
Acoms Techniplus controller, and an Acoms 2channel receiver.
I still have the standard motor too
You can see both of these in the photos below, you can also see close-ups of my wiring.
The battery is plugged in and charged.[img][/img]
THE PROBLEM:
Ok, so i turn the controller on (trimming in neutral) and then turn the car on, ESC starts beeping. At this point its going beep.. beep.. beep and
the Steering servo works fine
So i turn it off and then turn on the controller followed by the car and now every time the ESC beeps the motor jolts and the wheels nudge forwards. now the ESC goes beeeep beep beeeep beep and stops
RIGHT NOW when i turn it on it doesn't beep or jolt at all, the steering servo still works but no motor, i plugged another spare servo into the receiver and that worked fine.
Please can you have a look at the pictures and the video ! My wiring may be wrong or something simple but i need your help !
If you want any more info, i'll be watching this like a hawk so just ask.
Thank you very much in advance !
[youtube]http://www.youtube.com/watch?v=E-7_Hd8M_2U[/youtube]
I just uploaded the video so it may still be prosesing
