RE: DL-50 engine
Eric,
If you are going to use dual batteries you should use a battery share device. It keeps the batteries isolated from each other so if one battery goes bad it won't drain the other battery down with it. If you just plug both batteries into the reciever and one battery goes dead both batteries will equalize throgh the reciever and both will be dead, your plane will soon follow.
