RCU Forums - View Single Post - Can I use flexible pushrod for the elevator?
Old 03-26-2009 | 02:59 PM
avionette
Default RE: Can I use flexible pushrod for the elevator?
ORIGINAL: Erebus
ORIGINAL: avionette
Hi everyone
i have used these gt accuglide semi-flex om my busa 1/6 scale pup first i saved a lot of weight i got the model light tha say instructin manual but i'm afraid that in summer period these will have problem about thermal expansion!!is there someone had problem about thermal expansion?
There are several of these types of pushrods available, depending on the size of the model. Also you can buy the flexible Sullivan composite Flex Rods, and they do not shrink or expand. Although I have used all of them, the only ones that I had problems with were the white GP pushrods that came with my old prop F-4 Phantom kit. I simply replaced them with the Composite Flex Rods and everything was fine.
http://www3.towerhobbies.com/cgi-bin...?&I=LXFV43&P=7
Hi when you say composite you refer to the carbon fiberglass?
