RCU Forums - View Single Post - Cyclic sensitivity for a beginner
Old 03-27-2009 | 11:27 PM
bad400
Default RE: Cyclic sensitivity for a beginner
ORIGINAL: BigSting23
I'd like to program a controller, but i'm just using the TX that came with the Heli right now and I don't think I can program it.
So move the links away from the servo should calm it down a little bit? Obviously I will move them back, but I'm having a hard time controlling it for a hover due to the sensitivity.
yes moveing the linkage further out on the arms.horns will slow down the swashplate movement.
are you sure you cant plug your radio/tx into your computer and change your preprogramed settings?
you can go into the esky forum and see if the cat from ushobbysupply can give some insight on the radio`s
