RCU Forums - View Single Post - Nylon hinges
Thread: Nylon hinges
Old 03-28-2009 | 12:55 PM
Fastsky's Avatar
Fastsky
Default RE: Nylon hinges
Please use the Hinge glue. It will hold much better than epoxy on plastic hinges and won't clog up the centre pin as bad either. I then use round tooth picks with wood glue to pin the hinge. Works well and never a failure. Unless you are flying smaller models such as maybe .25 size then I would use the larger medium size hinges instead of the small ones you listed.
