RCU Forums - View Single Post - Help with Walbro Carb on a Brillelli SPE engine
Old 03-28-2009 | 06:18 PM
Super08's Avatar
Super08
Default RE: Help with Walbro Carb on a Brillelli SPE engine
You need to run a hose between the two nipples in the first picture. This is for your pulse pressure to run the fuel pump.
The nipple on the left in the second picture and on top in the last picture is where your gas line hooks on.
I can't quite see but if there is another nipple on the back it is not used and should be plugged if it is not plugged already.
