ORIGINAL: djangomangalam
So here is what I've done/ am going to do. I've angle the servo so that the pushrod is now longer traveling diagonally toward the ball link connected to the tail. I'm also going to get the aluminum upgrade so it hopefully won't break as easily. Does that sound ok?
yeah and as suggested (depending on your gyro type) check the endpoints in rate mode.The part you linked to above looks like the copterX tail part,there must be a dozen different tail setups floating around but 90% of em are interchangeable
cheers
Wozza
