RE: Monster Drifter
Savage suspension is so stiff I won't need sway bars.slides realy flat.will post some vids as soon as i can find someone w/vid camera.i used PVC pipe couplers,all you have to do is cut ring inside the coupler out,then you can slide you're wheel right through&glue it in place.it is a blast although i need to gear up alot due to smaller tire dia. I'll keep you posted.[sm=teeth_smile.gif]
