Monster Drifter
CO
okay you guys are going to laugh at me.i have a Losi LST & 3 SAVAGE trucks, i want to turn one of them into a drifter. i found this on YOU TUBE check it out! RC DRIFTING-Kaigon Dori Drift .I'm so stoked,cause i thought i had a stupid idea.then find out some one is realy doing this. Maybe you guys have seen this done,but i'm NOOB to DRIFTING,just wanna get sidways.figure i should use what i have!
CO
Savage suspension is so stiff I won't need sway bars.slides realy flat.will post some vids as soon as i can find someone w/vid camera.i used PVC pipe couplers,all you have to do is cut ring inside the coupler out,then you can slide you're wheel right through&glue it in place.it is a blast although i need to gear up alot due to smaller tire dia. I'll keep you posted.[sm=teeth_smile.gif]
