RE: Differential Distress...Need a little help.
Thanks guys. Now there is still the question of are the innards of the "complete rear differential" the same innards of the "rear differential assembly spiral 2008"- minus the spiral pinion gear and the set of bearings? Have a look if you want at the two: [link]http://largescalerc.com/index.asp?PageAction=VIEWPROD&ProdID=379[/link] is the complete one, and [link]http://largescalerc.com/index.asp?PageAction=VIEWPROD&ProdID=1621[/link] is the "rear differential assembly spiral 2008"
