RE: Thunder Tiger p51 Nose Over
Thought i would let you guys know what the fix was. The landing gear wire was very weak as is with most arfs i have had, I went to my local welding shop and got some heavy welding rod and heated and bent it to fit but made them 3/4 inch longer and put the axle at leading edge of wing. This puts the wheel centered on the leading edge of the wing. Now it couldnt be better. THANKS
