RCU Forums - View Single Post - Degrees into inches to setup controls
Old 03-31-2009 | 06:01 PM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: Degrees into inches to setup controls
Sort of... Ten degrees on a smaller control surface would be a small amount of throw, while ten degrees on a large control surface would be much more throw.
What you can do is measure the widest part of the control surface (front to back), call it :"X". Call the amount of degrees "D". XsinD=throw in inches. Make sure your calculator is in degrees and not radians. Measure your throw from that widest point.
