RCU Forums - View Single Post - senior telemaster
Old 03-31-2009 | 09:51 PM
deerhunter_deer's Avatar
deerhunter_deer
Default senior telemaster
Just a FYI
I recieved my senior telemaster an ARF about 3 weeks ago.. and began going over it. I found that the hindges were held in by one small screw.. No glue at all. I replace all with http://www3.towerhobbies.com/cgi-bin...&I=LXK114&P=ML
They fit in the exsisting slots and function much better
Also you may want to add some real epoxy to this plane. I'm not sure what kind of glue they used but it's not much to brag about.
A little info about this build
Putting a 25cc gas on it.
added 50% to rudder (more control at slow speeds)
may do flapperons not sure yet
Moving all servos back, way back making room for drop box.
getting rid of the rubber band idea and making a much better way to attach the wing
Build is going great all I have left is to hook up the pull-pull on rudder, finish fuel lines and double check CG
