RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 04-01-2009 | 08:32 AM
  #4348
Bosco2
My Feedback: (42)
Default RE: DL-50 engine
ORIGINAL: paul5992
I've had my muffler fall off 3 times. So do yourself a favor. Go to the hardware store and buy yourself some new bolts that are long enough to go threw the muffler and threw all the threads of the head on the motor. Also buy some washers that will fit in the muffler bolt holes. Also get some red lock tight or some other permanent loctite. I've had to buy an 80 dollar Heili coil set because I thought I new better. Do what you want. But if you don't do it right you will be back on here asking me where I got my heili coil set.
I had to go with the heili coil system cost me the same but the best part is that it works very well even affter removing the muffler several time affter,
