RCU Forums - View Single Post - Help with Walbro Carb on a Brillelli SPE engine
Old 04-01-2009 | 10:38 PM
Super08's Avatar
Super08
Default RE: Help with Walbro Carb on a Brillelli SPE engine
Sounds like you are not getting pulse pressure to the carb. Check to see that there are no leaks or blockages from the little hole in the cylinder head through the insulator going to the hose that you hooked up between the two nipples on top in the first picture.
