RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 04-02-2009 | 06:57 PM
  #4411
Helicam Oaxaca
Default RE: DL-50 engine
ORIGINAL: jedijody
ORIGINAL: Helicam Oaxaca
Hi all I own a DL50 that I have installed in my EF Extra 300 88" and I´m very happy with the engine, so happy that I got two new DL50's for my Ziroli P38, I already have the plans and all the glass parts and I´m waiting for the wood that should be here next week, my question is, can I modify one of the engines to have counter rotating engines in my P38? is this posible? Has any one made this modification?
Thanks in advance
Rafael Castaneda
Oaxaca Mexico
This should be possible without to much trouble, 2 stroke engines really don't even know which way they are turning. All that really needs to be done is to relocate the sensor to achieve the required 28-30 degrees BTDC ignition timing while turning the other direction.
Thank you Jody, I will try to make the change and see what's the outcome I have time until I build the firewall of my Ziroli P38 and I will post the results.
