ORIGINAL: Hoosier06
I have one and I set the charging parameters for charging Lipos. The charger does not read your Lipo, you have to set the charge rate and the number of cells in your lipo. If you do not have a manual you can download one from thre Hyperion website. The process is- select battery type-select charge rate- select number of cells. It is a fine charger.
Thanks, unfortunatley the charger still doesn't work. I've got 2 packs at 2100mAh at 3s. Looks for batt. connector, then battery, and says no battery.
