RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 04-03-2009 | 10:23 PM
  #4447
brewski
Default RE: DL-50 engine
Why wouldn't a choke servo serve the same purpose? If you have a need to kill the engine in the air, simply hit the choke switch. Does the opti kill still work if you lose receiver power or radio signal? Even in that case the engne should go to fail safe which could be set at below idle and shut down the engine if you remove the idle screw.
