RE: sloppy aileron
Mix up some 30 minute epoxy and see if you can load it up using a toothpick. You may need to open up the ends around the control rod to get enough deflection to work the toothpick enought to start filling up the well. Also work a small piece of waxpaper between the rod and the wing before you get started.
