ORIGINAL: xjqkz
HUDY off road setup station is close to $350 but if you really don't want to use your eye then you can get a camber gauge(RPM), ride height gauge (losi), toe gauge (RPM), and a digital caliper all for under $50. That should be able to get you going.
the Hudy station is 160$ ..+ a truggy top plate if you need one. NOT 350$.....as for a board.....a 5$ piece of counter top works just fine.
