RCU Forums - View Single Post - Stinger Build Thread
Old 04-04-2009 | 01:08 PM
sahartman21
Default RE: Stinger Build Thread
Once the epoxy is applied to the skins it is time to wrap the skins around the cores.
I laid the cores between the skin. Part of the skin wraps from the trailing edge over the top of the core.
Slide that assembly between the top and bottom shucks. Do your best to align the cores in the same relative position as they were cut.
I temporarily pinned the assembly together with tee pins. Wrap some masking tape around the assembly to hold parts together. Once taped together remove the pins that initially lined up all the parts.
