RCU Forums - View Single Post - Stinger Build Thread
Old 04-04-2009 | 02:52 PM
sahartman21
Default RE: Stinger Build Thread
Trim the tips and double check the alignment of the cores in the shucks.
After aligned apply Tee Pins as needed to hold parts in alignment.
Remove the tape and trim the skins flush with the leading and trailing edge.
Sand the leading edge as a piece of balsa will later be glued there.
ID:	1172530   Click image for larger version
ID:	1172531   Click image for larger version
ID:	1172532   Click image for larger version
