ORIGINAL: torpedochief
Hey SSR,
Well my brother it looks like you get to got hunting. Actually it sounds like one of the wires that goes to the little six place board has come loose. No big deal. Just take off the tracks. Take thethree body and six sponson screws out.
Lift off the top (ever so carefully) When you are clear remove the 8 pin connector and then turn the hull upside down and look at the wires just to the side of the turret rotation motor. Resolder and reverse the above.
If all the wires look good then you might have a bad board. What a great time to upgrade to an RX-18.
Don
Thanks for the help, I will take a look in there and see what I can find. What's the difference between the RX-18 and the board it would have in there now?
