RE: post some pictures of your pattern plane!!
Hi
Keith
She flies very well. Downlines are slow. Rollings are very accurate (weight of wings and carbon tube is 970 g / 34 ounces).
Incidence wing is 1 mm and incidence stab is zéro. CG is 36 %.
There are a little bit mix rudder> elevator and mix rudder > aileron.
Ryan
Thickness of trailing edges is 10 mm (0.4 inch). Airfoil is NACA 64012a (same as Oxalys) .
Regards
