RE: GMS 2000 47 won't run
Also, if you have the needle valve mounted remotely, move it to the carb. Unscrew the dome nut from the carb, take out the small plastic insert and screw in the needle valve assembly. The NV assembly and carb is designed to have the NV in either position. This seems to be very beneficial to making GMS engines run well. If this doesn't help , then do the drilling thing.
