RCU Forums - View Single Post - Gadget conversion?
Old 04-06-2009 | 01:53 PM
gcb
Default RE: Gadget conversion?
ORIGINAL: NvMike
I would like to convert an OS40 LA to diesel. Has anyone tried the Gadget Diesel Conversion Adapter? Is so what is the fuel mixture to use?
Mike,
Just a suggestion but I would contact Mr. Davis about one of his excellent conversion heads. It uses standard model diesel fuel and folks have raved about it.
If you take the time to read that link above, you will find that results are "iffy" and you need to mix a special fuel. At least, that what I got from it.
Good luck either way.
George
