ORIGINAL: ssrc30
ORIGINAL: YHR
Hey, you are right in town. I'll be able to fix whatever might be wrong with it. Up movement on theleft joystick fires the gun. Down makes the bbl elevate. As you have no elevation or gun firing it might be the left Joystick gimble causing trouble. No fear I have lots of those too.
Bring it over to the house and we will we get it fixed
Ya I think I might have to do that because I don't have a clue whats going on here lol.... The only time the left stick seems to make the gun fire is when the motor for the bb gun is turned on. When that motor is turned off the stick does nithing. There is a button on the TX that controls the gun firing while the BB gun is switched off.
Ya that is how they are designed to work. Gun elevation isn't up and down with the joystick. There is a cam inside the tank that rotates, so gun elevation is down on the left joystick, and hold it down and the gun will cycle through a complete up and down movement.
