RCU Forums - View Single Post - Optimal Temputures
Old 06-16-2003 | 05:40 PM
BUGGIES_R_US's Avatar
BUGGIES_R_US
Default Optimal Temputures
Well.. every engine runs best at a particular temperature depending on the following variables:
1) Temperature
2) Humidity
3) Fuel nitro and oil %
4) Your style (hi speed runs or blips of throttle?)
Funny thing is high end engines tend to run better when hot than cheaper engines.
Typical engines run well at 225-240 but more expensive engines run well at 250-275.
When running at WOT you should have a clean trail of smoke.
IF your engine sputters or hesitates in any RPM range/band, then you can lean it a bit.
Hope that helps.
Ram
