RCU Forums - View Single Post - Blackjack 26 BL
Old 04-07-2009 | 09:43 AM
Apache-Sven's Avatar
Apache-Sven
Default RE: Blackjack 26 BL
Ok so far I've received the rudders, Octura prop, hydra 240 and water cooled motor mount and this is what it looks like so far. Keeping in mind that only the rudders are actually installed properly.
The motor is just the stock motor for show until I pick up the 7xl, but this is basically the way the boat will be setup. The Hydra has had it's BEC removed so I can run my 4s setup without damage. The turn fins have been angled inward for better cornering. The stock water pick up has been removed for the purpose of looks but the entire drive system will be replaced with and OSE catamaran rudder-behind-prop system, as soon as it arrives. The batteries have been dropped down in the transom as low as possible and as far back as possible. The Shaft will need to be replaced as it has somehow become damaged. I believe that it was twisting in the wrong direction therefore the prop might need to be changed to a right hand prop. The dual water pickups will be split up to cool separate components. One will cool the motor and mount while the other will cool the Hydra. I will also place another outlet to the right side of the boat for symmetrical water exits.
The boat as it sits right now has it's cg at 6 inches from the rear. Here are some pictures for you to see how she looks so far. Again keep in mind that the boat is still under major construction and will not look dirty with messy wires hanging around it will look professional and clean.
ID:	1174993   Click image for larger version
ID:	1174994   Click image for larger version
ID:	1174995   Click image for larger version
ID:	1174996   Click image for larger version
ID:	1174997   Click image for larger version
