RCU Forums - View Single Post - Swashplate question
Old 04-07-2009 | 02:53 PM
bighuhu
Default RE: Swashplate question
I had the same problem, 1956. I believe that the two pieces should be a press fit. I cleaned the two parts, then I put a small drop of zap a gap on the top piece, then slid it into the lower part. You don't need to be concerned how to orient it since it is a bearing. Be careful not to get any cement into the the bearing itself.
