RE: Stinger Build Thread
Scott- so what you end up with is a 3/4" thick slab of balsa with a fiberglass stiffener in the middle, that you can glue on to the end of the wing, then shape? The glass (and epoxy) add stiffness with minimum weight gain I assume. Keep on posting, learning from every one! Randy
