ORIGINAL: Countryboy
Since there seems to be no definitive answer to what I feel is a real & risky issue, I took it upon myself to modify the Spektrum module casing. By this mod I was able to triple the pin depth into the module receptacle. The module also now snaps in tight with no movement.
It isn't clear what or how you modified your module to fit tight and positive??? Any detail info will be appreciated?[sm=confused.gif][sm=confused.gif]
