I bought some sample motors "PULSO X series 2208/34, 2826/8" from a new manufacturer of burshless motor-www.danlions.com.
PULSO X Series Brushless Motors are designed to RC aircrafts and helicopters. They have very nice winding and very high precision assembly. All PULSO X series brushless motors have installed 3.5mm gold connectors. The standard accessories include mounting flange, propeller adaptor, securing collar, and screws.
I can't help introducing it to all of you.
Try it right now. You will get a fantastic experience.
Specifications
Model Number: X2826/8
Rotation Speed: 1130 Kv / RPM/V
No-Load Current: 2.9 Amps @ 10 volts
Motor Resistance: 30mΩ
Max. efficiency current: 25-37A(>75%)
Current capacity: 55A/30s
Max efficiency: 83%
Body Dimensions (Diameter x Length): 35mm x 54mm
Shaft Dimensions (Diameter): 5mm
Number of lipo cells: 2-3 Cells
Recommend Model: Airplane
[8D]
Olivier
