RE: jato 3.3 many problems
well, get some high temp silicone, and seal around the neck of the carb where it touches the block (you will have to take the carb off of the motor). then pull off your easy starter or pull start, then remove the back plate under it (when it's off you will be able to see the connecting rod and crank), then seal it up and you should be ready after you let it sit for about a day.
