RCU Forums - View Single Post - Measuring Total Plane Drag
Old 04-12-2009 | 12:26 PM
CrateCruncher's Avatar
CrateCruncher
Default RE: Measuring Total Plane Drag
ORIGINAL: da Rock
Have you an explanation for consideration of density altitude? I've been recording it since the 70s whenever I do any kind of testing, especially prop tests. Most would be amazed exactly how much it differs, even from day to day. And not many would realize how much it affects our model performance. It's probably the one most important unknown that makes a great deal of our testing of little real value.
As an aside, nowadays it's actually quite easy to take very accurate readings of it. There are handheld "weather stations" quite reasonably priced that do quite an excellent job of recording just about everything.
Hi da Rock,
I can't speak for Rotaryphile but my Terminal Dive calculation assumed 90F and 500 ft for the air density number. Austins about 200 ft above sea level and HOT and I need about 300 feet to pull out. Naturally each data run would have an actual temperature and ground pressure recorded. I use a La Crosse weatherstation thats battery powered.
